Автомобиль Skoda Octavia A7FL, декабрь 18 года, российской сборки
Скачал версию 18.9.1EN, но при входе во все блоки недоступны измерения, а также вся правая часть(адаптации, кодирование и т.д.), просит обновить интерфейс. Есть ли какие-то методы?
Monday,22,April,2019,18:17:53:46766
AVTO -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
AVTO Version: 18.9.0.4
Data version: 20190114 DS296.0
www.avtoadapter.ru
VIN: XW8AN4NE0KH016175 License Plate: 930
Chassis Type: NE (3Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 5F 75 BB BC
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
75-Telematics -- Status: OK 0000
BB-Door Rear Drv -- Status: Not registered 0001
BC-Door Rear Pass -- Status: Not registered 0001
Address 01: Engine (J623-CWVA) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 057 EL HW: 04E 907 309 CP
Component: R4 1.6l MPI H24 5379
Revision: 31H24000
Coding: 011A0012030400000000
Shop #: WSC 73430 790 00035
ASAM Dataset: EV_ECM16MPI01104E906057EL 001005
ROD: N/A
VCID:
Unsupported vehicle.Please upgrade to a current interface.
No ASAM data for: "EV_ECM16MPI01104E906057EL" ()
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans (J217) Labels: 09G-927-749-V2.clb
Part No SW: 09G 927 158 AH HW: 09G 927 158
Component: AISIN AG6 G3 204 3353
Coding: 010100000C000000000000000000000000000000
Shop #: WSC 73430 031 00047
ASAM Dataset: EV_TCMAQ250031 002009
ROD: N/A
VCID:
No ASAM data for: "EV_TCMAQ250031" ()
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 5Q0 614 517 DF HW: 5Q0 614 517 AF
Component: ESC H62 0974
Revision: 00000000 Serial number: 63078000000145
Coding: 24076A91242121724078060760C8242456248402600624322043F0004002430B00000012121212B835351919323200
Shop #: WSC 73430 031 00035
ASAM Dataset: EV_Brake1UDSContiMK100ESP 037009
ROD: N/A
VCID:
No ASAM data for: "EV_Brake1UDSContiMK100ESP" ()
Address 08: Auto HVAC (J255) Labels:. 5G0-907-044.clb
Part No SW: 5E0 907 044 AS HW: 5E0 907 044 AS
Component: Climatronic H04 2002
Revision: 00001K00
Coding: 01010004000100010005000900101022
Shop #: WSC 33361 790 00035
ASAM Dataset: EV_ACClimaBHBVW37X 006147
ROD: N/A
VCID:
No ASAM data for: "EV_ACClimaBHBVW37X" ()
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5Q0 937 084 DC HW: 5Q0 937 084 CF
Component: BCM MQBAB M+ H38 0273
Serial number: 00001829603788
Coding: 000000000000000000000000000000000000000000000000000000000000
ASAM Dataset: EV_BCMMQB 019001
ROD: N/A
VCID:
Subsystem 1 - Part No SW: 5E1 955 119 A HW: 5E1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS371 181025 051 0916
Serial number: 887353F0401829806876
Coding: 164DDD
Subsystem 2 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
Component: RLHS 052 0107
Serial number: S7Y18M11D06H15M37S24
Coding: 00885D
No ASAM data for: "EV_BCMMQB" ()
Address 10: Park/Steer Assist (J446) Labels:. 5Q0-919-294.clb
Part No SW: 5QA 919 294 C HW: 5QA 919 294
Component: PDC 8 KanalH07 0050
Serial number: 000308418018299
Coding: 0471051011
ASAM Dataset: EV_EPHVA18AU3700000 009039
ROD: N/A
VCID:
No ASAM data for: "EV_EPHVA18AU3700000" ()
Address 15: Airbags (J234) Labels:. 5Q0-959-655.clb
Part No SW: 3Q0 959 655 CQ HW: 3Q0 959 655 CQ
Component: Airbag VW21 006 0720
Revision: -------- Serial number: 003Z5PQ071Q%
Coding: 88C0C00000000000400000CC000840000065
Shop #: WSC 73430 790 00063
ASAM Dataset: EV_AirbaVW21TS6VW48X 001014
ROD: N/A
VCID:
Subsystem 1 - Part No SW: ----------- HW: 454 003 010 18
Component: SideSensor_Df 008 0887
Serial number: 3570000000092BF4623O
Coding: 2D2D2D
Subsystem 2 - Part No SW: ----------- HW: 454 000 111 18
Component: SideSensor_Pf 008 0887
Serial number: 35800000000F235D923P
Coding: 2D2D2D
Subsystem 3 - Part No SW: ----------- HW: 454 801 510 18
Component: SideSensor_Dr 301 0148
Serial number: 3510065D7A116000000F
Coding: 2D2D2D
Subsystem 4 - Part No SW: ----------- HW: 454 801 110 18
Component: SideSensor_Pr 301 0148
Serial number: 35200A2E77D16000000R
Coding: 2D2D2D
Subsystem 5 - Part No SW: ----------- HW: 454 803 110 18
Component: FrontSensor_D 304 0149
Serial number: 3550051A0A3160000006
Coding: 2D2D2D
No ASAM data for: "EV_AirbaVW21TS6VW48X" ()
Address 16: Steering wheel (J527) Labels:. 5Q0-953-549.clb
Part No SW: 5Q0 953 507 FD HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0140
Revision: -------- Serial number: 02111820240313
Coding: 0010
ASAM Dataset: EV_SMLSKLOMQB 020002
ROD: N/A
VCID:
No ASAM data for: "EV_SMLSKLOMQB" ()
Address 17: Instruments (J285) Labels:. 5G0-920-XXX-17.clb
Part No SW: 5E0 920 780 F HW: 5E0 920 780 F
Component: KOMBI 202 3610
Coding: 07A402082080000810083A001001000800000000
ASAM Dataset: EV_DashBoardJCIMQBAB 009009
ROD: N/A
VCID:
No ASAM data for: "EV_DashBoardJCIMQBAB" ()
Address 19: CAN Gateway (J533) Labels:. 3Q0-907-530-V1.clb
Part No SW: 3Q0 907 530 Q HW: 3Q0 907 530 C
Component: GW MQB High 518 5344
Serial number: 02111810800026
Coding: 0901000874086400EB0002081C0F00000001070000000000000000000000
ASAM Dataset: EV_GatewNF 013023
ROD: N/A
VCID:
Component: 1-00-05-00-04
Subsystem 2 - Part No SW: 3V0 919 719 E HW: 3V0 919 719 E
Component: E221__MFL-PR6 H03 0170
Serial number: 000000000B3554091118
Subsystem 3 - Part No SW: 5Q0 907 155 B HW: 5Q0 907 155 B
Component: U13DCAC H25 0780
Serial number: 2072838
No ASAM data for: "EV_GatewNF" ()
Address 42: Door Elect, Driver (J386) Labels: None
Part No SW: 5Q4 959 393 F HW: 5Q4 959 393 F
Component: TSG FS 006 0246
Serial number: 0000353208414
Coding: 001001208000020000001100
ASAM Dataset: EV_DCU2DriveSideMAXHCONT 001005
ROD: N/A
VCID:
Subsystem 1 - Part No SW: 5Q0 959 811 E HW: 5Q0 959 811 E Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_DRV 006 0007
Serial number: 00000000000025103640
Coding: 010200
No ASAM data for: "EV_DCU2DriveSideMAXHCONT" ()
Address 44: Steering Assist (J500) Labels:. 5Q0-909-144.clb
Part No SW: 5Q0 909 144 AB HW: 5Q0 909 144 AA
Component: EPS_MQB_ZFLS 131 1082
Coding: 01020000
ASAM Dataset: EV_SteerAssisMQB 015157
ROD: N/A
VCID:
No ASAM data for: "EV_SteerAssisMQB" ()
Address 52: Door Elect, Pass. (J387) Labels: None
Part No SW: 5Q4 959 392 F HW: 5Q4 959 392 F
Component: TSG BFS 006 0246
Serial number: 0000353231923
ASAM Dataset: EV_DCU2PasseSideMAXHCONT 001005
ROD: N/A
VCID:
Subsystem 1 - Part No SW: 5Q0 959 812 E HW: 5Q0 959 812 E Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_PSG 006 0007
Serial number: 00000000000023952176
Coding: 190200
No ASAM data for: "EV_DCU2PasseSideMAXHCONT" ()
Address 5F: Information Electr. (J794) Labels:. 3V0-035-MIB-STD2.clb
Part No SW: 5Q0 035 840 C HW: 5Q0 035 840 C
Component: MU-S--ER H41 0472
Serial number: SKZAZ2U0935121
Coding: 03730100FF00000041110001000100002F0208C40120050002
ASAM Dataset: EV_MUStd4CTSAT 001022
ROD: N/A
VCID:
Subsystem 1 - Part No SW: 5E0 919 605 N HW: 5E0 919 605 N
Component: ABT_Std-2 H52 8130
Serial number: SKZ6ZHV3032356
No ASAM data for: "EV_MUStd4CTSAT" ()
Address 75: Telematics (J949) Labels: None
Part No SW: 3Q0 035 284 HW: 3Q0 035 284
Component: OCULowMQBLGE H23 0577
Coding: 037301016916120D0000000040456003806608
Shop #: WSC 131071 1023 2097151
ASAM Dataset: EV_OCULowMQBLGE 003042
ROD: N/A
VCID:
No ASAM data for: "EV_OCULowMQBLGE" ()
Address BB: Door Rear Drv
Cannot be reached
Address BC: Door Rear Pass
Cannot be reached
End-------------------------(Elapsed Time: 03:54)--------------------------
Диагностика Skoda Octavia A7FL
Forum rules
Postby eu-ru » 22 Apr 2019, 19:41
- Снимок экрана (1).png (353.93 KiB) Viewed 13263 times
Re: Диагностика Skoda Octavia A7FL
Postby ilia2108 » 23 Apr 2019, 11:25
Заканчиваем тестирование и выпускаем обновление, будет работать. Если хотите поучаствовать в тестировании, дам ссылку на рабочую версию.
Postby ilia2108 » 23 Apr 2019, 11:53
Готово
Postby Sashchen » 23 Apr 2019, 11:58
Давайте и я на Ауди протестирую. Мы все хотим чтобы все работало без каких либо загвоздок. Только напишите куда сообщать.
Postby ilia2108 » 23 Apr 2019, 12:01
Послал.
Пишите на labels@avtoadapter.ru
Postby noxx97 » 07 Sep 2019, 10:56
Добрый день, Илья!
Пришлите, пожалуйста, мне тоже ссылочку на прогу. Такая же беда, по двум последним блокам
BB-Задн.лев.дверь -- Статус: Не зарегистрировано 0001
BC-Задн.прав.дверь -- Статус: Не зарегистрировано 0001
Postby ilia2108 » 08 Sep 2019, 12:13
Какой версией пользуетесь?Добрый день, Илья!
Сейчас актуальная 18.90, скачивайте тут.
