ребята помогите разобраться с ошипками Chassis Type: 3C (3C0)
Scan: 01 03 08 09 10 15 16 17 19 25 37 42 44 46 52 53 55 56 5D 62
72 77
VIN: WVWZZZ3CZAP018400
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 1010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Malfunction 1010
5D-Operations -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 19: CAN Gateway Labels: 3C0-907-530-V3.clb
Part No SW: 3C0 907 530 L HW: 3C0 907 951
Component: J533__Gateway H13 0152
Revision: H13 Serial number: 3300P098290516
Coding: F9A17F06402602001002
Shop #: WSC 00028 028 00001
VCID: 2A511AE88501E84EEA7-807F
2 Faults Found:
01300 - Control Module for Navigation with CD-Rom (J401)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 6
Reset counter: 181
Mileage: 145793 km
Time Indication: 0
Date: 2048.14.07
Time: 14:56:50
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 181
Mileage: 145793 km
Time Indication: 0
Date: 2048.14.07
Time: 14:56:50
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 P HW: 1T0 035 680 P
Component: RNS-MID H70 5238
Revision: AB001001 Serial number: VWZ6Z7L7403501
Coding: 00000400000000000000
Shop #: WSC 00000 000 00000
VCID: 3B7F2FACBA9B61C6811-806E
Subsystem 1 - Part No: 1T0 919 859 B
Component: EU West V10 8048
4 Faults Found:
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 5
Fault Frequency: 6
Reset counter: 142
Mileage: 146200 km
Time Indication: 0
00856 - Radio Antenna
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 20
Reset counter: 142
Mileage: 146200 km
Time Indication: 0
03138 - Input AUX IN
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 141
Mileage: 146200 km
Time Indication: 0
Date: 2049.14.01
Time: 12:56:38
01523 - Microphone for Telephone (R38)
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 11
Reset counter: 142
Mileage: 146200 km
Time Indication: 0
Date: 2049.14.01
Time: 12:56:45
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Part No SW: 3C0 959 433 AR HW: 3C0 959 433 AR
Component: KSG PQ46 ELV 043 0612
Revision: 00043000 Serial number: VWZCZ000000000
Coding: 00910A0001860E763004941570084F0E707C01
VCID: 7AF1EAA8352198CEDA7-802F
Subsystem 1 - Part No: 1K8 951 605
Component: LIN BACKUP HORN H09 9002
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
1 Fault Found:
01134 - Alarm Horn (H12)
000 - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 37
Mileage: 138653 km
Time Indication: 0
Date: 2043.14.27
Time: 12:26:12
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
4 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 6
Reset counter: 142
Mileage: 146200 km
Time Indication: 0
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 20
Reset counter: 142
Mileage: 146200 km
Time Indication: 0
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 141
Mileage: 146200 km
Time Indication: 0
Date: 2049.14.01
Time: 12:56:38
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 11
Reset counter: 142
Mileage: 146200 km
Time Indication: 0
Date: 2049.14.01
Time: 12:56:45
Address 77: Telephone Labels: 3C0-035-730.lbl
Part No SW: 5N0 035 730 B HW: 5N0 035 730 B
Component: J412 8502
Revision: 00015000 Serial number: 0000B7A112098
Coding: 0020155
VCID: 2757E3DC9613D526F59-8072
4 Faults Found:
00385 - Positive Output Audio Channel for Speech/Telephone
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 161
Mileage: 145788 km
Time Indication: 0
Date: 2048.14.06
Time: 12:20:51
00386 - Negative Output Audio Channel for Speech/Telephone
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 161
Mileage: 145788 km
Time Indication: 0
Date: 2048.14.06
Time: 12:20:51
01304 - Radio
Freeze Frame:
Fault Priority: 3
Fault Frequency: 6
Reset counter: 181
Mileage: 145793 km
Time Indication: 0
Date: 2048.14.07
Time: 14:56:50
00992 - Consumption Cut-Off Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 3
Reset counter: 181
Mileage: 146200 km
Time Indication: 0
Date: 2048.14.31
Time: 12:01:25
помогите устранить ошибки
dima7611163
Re: помогите устранить ошибки
Postby ilia2108 » 17 Jan 2014, 10:56
Сбросьте ошибки, думаю много из них обратно не появятся, т.к. вообще висят после сняния магнитолы.
Те которые появятся снова - посмотрим.
dima7611163
Postby dima7611163 » 17 Jan 2014, 13:42
привет как тыговарил я все сделал некоторые ошибки ушли 3 ошибки остались помоги их устронить
Gateway Installation List: 3C0 907 530 L
19-CAN Gateway -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
ошибки в блоках 37,46 и 56 да еще я думаю это все и за прошивки магнит 510 что то слетело зарание спасибо
Postby ilia2108 » 20 Jan 2014, 16:20
Какие конкретно ошибки остались?
Как радио себя ведёт приём нормальный? Такое впечатление, что RNS510 туда втыкали на место какой-нибудь RCD310. Тогда антенна стоит физически одна, а не 2 как ищет РНСка, приём может при этом и быть, но ошибку никуда не деть без установки второй антенны. А если аукс физически не установлен, его можно отключить в кодировании блока.
По центральной элеткронике - ошибка с сиреной. Предохранитель/подключение/проводка/сама сирена.
dima7611163
Postby dima7611163 » 21 Jan 2014, 12:39
Component: RNS-MID H70 5218
Coding: 00010400010000A00000
Shop #: WSC 12345 123 12345
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 20
Reset counter: 147
Mileage: 146576 km
Time Indication: 0
Coding: 00910A0001864E763004941570084F0E707C01
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 146
Mileage: 146583 km
Time Indication: 0
Date: 2049.14.11
Time: 13:22:22
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 20
Reset counter: 147
Mileage: 146576 km
Time Indication: 0
привет радио работает хорошо до этого стояла навиг rns310 поставил 510 штекера в зади такие может плохой контакт попробую снять и занова ваткнуть штекера радио и навиг антены по поводу сигнализ предохранители с мотрел в салоне все нормальные а как можно проверить в реале работает она сигнализ есть тест какой та может пищалка вобще у меня не стоит я что то не нашол ее ошибки не збрасываються чем можешь помоги спасибо за помощь
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 20
Reset counter: 147
Mileage: 146576 km
Time Indication: 0
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 146
Mileage: 146583 km
Time Indication: 0
Date: 2049.14.11
Time: 13:22:22
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 20
Reset counter: 147
Mileage: 146576 km
Time Indication: 0
Postby ilia2108 » 26 Jan 2014, 20:37
Так ошибка по сигнализации как раз о том, что не стоит пищалки. По идее, можно в 46 блоке где-то указать что ее не установлено, тогда ошибка уйдёт.
А по антенне точно не скажу, возможно стоят 2 антенны, но одна активная, а другая пассивная. Голова ищет две активных и отсюда ошибка. Без установки второй активной ошибка не уйдёт, но какой смысл ее ставить, если радио работает нормально..
