Audi Q7-4,2TDI-2008 год
kosha76
Postby kosha76 » 25 Nov 2010, 01:17
Есть кучка ошибок по машинке. Не поможете разобраться куда копать в каждом случае?
Address 08: Auto HVAC Labels: None
Part No SW: 4L0 910 043 B HW: 4L0 820 043 L
Component: KLIMABETAETIGUNGH07 0040
Revision: 00---013 Serial number: 00000000181554
Coding: 0262168
Shop #: WSC 31414 790 00001
VCID: 234EEDD2DD8FEE04
3 Faults Found
00565 - Rear A/C Control Head (Climatronic) (E265)
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 2
Fault Frequency: 2
Reset counter: 194
Mileage: 4644 km
Time Indication: 0
Date: 2010.11.24
Time: 18:55:10
Freeze Frame:
ON
02763 - Potentiometer for Indirect Ventilation Flap Motor (G330)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 194
Mileage: 4644 km
Time Indication: 0
Date: 2010.11.24
Time: 18:55:10
Freeze Frame:
Voltage: 12.80 V
(no units): 86.0
(no units): 255.0
01334 - Door Control Module; Rear Right (J389)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 194
Mileage: 4644 km
Time Indication: 0
Date: 2010.11.24
Time: 18:55:10
Freeze Frame:
ON
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 D HW: 4L0 959 655 C
Component: 71 AIRBAG AUDI8RH43 0230
Revision: 04H43000 Serial number: 00399D05AJ9Y
Coding: 0014129
VCID: 2E580CE6864D536C
3 Faults Found
01590 - Igniter for Battery Disconnect (N253)
001 - Upper Limit Exceeded - MIL ON
01218 - Side Airbag Igniter; Passenger Side (N200)
00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
002 - Lower Limit Exceeded - MIL ON
Address 19: CAN Gateway (J533) Labels: 4F0-907-468.clb
Part No SW: 4F0 907 468 F HW: 4F0 907 468 F
Component: GW-BEM 4CAN-M H06 0022
Revision: LA602018 Serial number: 1800L087278126
Coding: 000003
VCID: 326018969275778C
Part No SW: 8K0 915 181 D HW: 8K0 915 181 D
Component: J367-BDM H07 0080
1 Fault Found
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 194
Mileage: 4644 km
Time Indication: 0
Date: 2010.11.24
Time: 19:07:35
Address 28: HVAC, Rear Labels: None
Part No SW: 4L0 910 158 HW: 4L0 919 158 D
Component: KLIMABETAETIGUNGH05 0060
Revision: 00---009 Serial number: 00000030103653
Coding: 0000006
VCID: E8D43AFEE4294D5C
3 Faults Found
00489 - Left Rear Vent Temperature Sensor (G405)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 194
Mileage: 4644 km
Time Indication: 0
Date: 2010.11.24
Time: 19:08:49
Freeze Frame:
Voltage: 14.50 V
01320 - Control Module for Climatronic (J255)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 194
Mileage: 4644 km
Time Indication: 0
Date: 2010.11.24
Time: 19:08:49
Freeze Frame:
ON
01849 - Temperature Sensor for Heated Seat; Left Rear (G94)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 194
Mileage: 4644 km
Time Indication: 0
Date: 2010.11.24
Time: 19:08:49
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 4F0 959 760 C HW: 4F0 959 760 C
Component: MEM-FS H08 0062
Revision: AA000000 Serial number: 00001001119897
Coding: 00581B00000011110000
VCID: 3162179A97734C94
1 Fault Found
01331 - Door Control Module; Driver Side (J386)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 194
Mileage: 4644 km
Time Indication: 0
Date: 2010.11.24
Time: 19:09:44
Address 42: Door Elect, Driver (J386) Labels: 4F0-959-793.clb
Part No SW: 4F0 959 793 R HW: 8K0 959 793 D
Component: TSG FA H11 0250
Revision: Serial number: 0000100165512
Coding: 010C52205040440004
VCID: 468854460EFDFB2C
1 Fault Found
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 194
Mileage: 4644 km
Time Indication: 0
Date: 2010.11.24
Time: 19:10:19
Address 47: Sound System Labels: 4L0-910-223-BO.lbl
Part No SW: 4L0 910 223 G HW: 4L0 035 223 D
Component: DSP-High AU716 H03 0150
Revision: PROD_01 Serial number: 00000000107440
Coding: 0000012
VCID: 2854FAFEA4A90D5C
1 Fault Found
02753 - Inside Microphone (R74)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 194
Mileage: 4644 km
Time Indication: 0
Date: 2010.11.24
Time: 19:11:50
Address 52: Door Elect, Pass. Labels: 4L0-910-793-52.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 792 B
Component: TSG BF H12 0150
Revision: 00000000 Serial number: Pr
Coding: 0035403
Shop #: WSC 03654 128 80736
VCID: 2F6611E281475A64
1 Fault Found
02123 - Door Warning Light / Entry Light
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 194
Mileage: 4644 km
Time Indication: 0
Date: 2010.11.24
Time: 19:25:34
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 Q HW: 4E0 035 541 S
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 388HB087699736
Coding: 0000001
1 Fault Found
00856 - Radio Antenna
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 230
Mileage: 4624 km
Time Indication: 0
Date: 2008.05.29
Time: 01:45:29
Address 62: Door, Rear Left (J388) Labels: 4F0-959-795.clb
Part No SW: 4F0 959 795 M HW: 8K0 959 795 B
Component: TSG HL H10 0251
Revision: Serial number: 0000100144392
Coding: 010C50204040230004
VCID: 438E4D523DCFCE04
1 Fault Found
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 191
Mileage: 4624 km
Time Indication: 0
Date: 2008.06.07
Time: 03:28:55
Address 6C: Back-up Cam. Labels: 4L0-910-441.lbl
Part No SW: 4L0 910 441 A HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J8740SG
Coding: 1021001
VCID: 244CEECED881E93C
2 Faults Found
01299 - Diagnostic Interface for Data Bus (J533)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 2
Reset counter: 231
Mileage: 4624 km
Time Indication: 0
Date: 2008.06.07
Time: 05:19:05
Freeze Frame:
Term 15 Off
Reverse OFF
Count: 3
02283 - Video Connection to Output [End Unit]
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 233
Mileage: 4630 km
Time Indication: 0
Date: 2008.05.29
Time: 23:26:00
Freeze Frame:
Term 15 On
Reverse OFF
Count: 4
Address 6D: Trunk Elect. Labels: None
Part No SW: 4L0 910 945 HW: 4L0 827 851 A
Component: ValeoHeckdeckel H20 0260
Revision: --H20001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: ECDC46EEF0D1617C
Part No: 4L0 910 946
Component: ValeoHeckdeckel H25 0290
2 Faults Found
00456 - Control Module for Access and Start Control (J518)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 231
Mileage: 4624 km
Time Indication: 0
Date: 2008.06.07
Time: 05:18:26
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 231
Mileage: 4624 km
Time Indication: 0
Date: 2008.06.07
Time: 05:19:05
Address 6F: Centr. Conv. II Labels: 4L0-910-290.lbl
Part No SW: 4L0 910 290 HW: 4L0 907 290
Component: ILM HINTEN 2 H05 0060
Revision: AAH05061 Serial number: 003783544-----
Coding: 0000005
VCID: E5CA33CA133B5034
3 Faults Found
02914 - Sensor 1 for Trunk/Hatch Closed (G525)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 1
Fault Frequency: 1
Reset counter: 231
Mileage: 4624 km
Time Indication: 0
Date: 2008.06.07
Time: 03:28:55
02915 - Sensor 2 for Trunk/Hatch Closed (G526)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 231
Mileage: 4624 km
Time Indication: 0
Date: 2008.06.07
Time: 03:28:55
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 231
Mileage: 4624 km
Time Indication: 0
Date: 2008.06.07
Time: 05:18:26
Address 72: Door, Rear Right
Cannot be reached
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 K HW: 4F0 919 283 K
Component: Parkhilfe 8-Kan H12 0100
Revision: 00H12000 Serial number: 69830821408762
Coding: 0221146
VCID: 2C5C06EEB051217C
2 Faults Found
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 231
Mileage: 4624 km
Time Indication: 0
Date: 2008.06.07
Time: 05:18:26
01315 - Transmission Control Module
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 231
Mileage: 4624 km
Time Indication: 0
Date: 2008.06.07
Time: 03:28:56
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4E0 910 336 M HW: 4E0 862 335
Component: Handyvorb2 H20 1130
Revision: 00000000 Serial number: 00000005247005
Coding: 0010900
1 Fault Found
02454 - Microphone Unit (in Front Roof Module) (R164)
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 191
Mileage: 4624 km
Time Indication: 0
Date: 2008.06.07
Time: 03:29:01
End ---------------------------------------------------------------------
Re: Audi Q7-4,2TDI-2008 год
Postby LittleTOXA » 30 Nov 2010, 23:09
удалено
Предлагаю сначала все ошибки стереть, а оставшиеся уже разберём :)
kosha76
Postby kosha76 » 13 Dec 2010, 22:42
На данный момент актуальна следующая ошибка:
Coding: 000003
1 Fault Found
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 194
Mileage: 4644 km
Time Indication: 0
Date: 2010.11.24
Time: 19:07:35
Cannot be reached
Электрик прозвонил все провода в задней правой двери. Вроде все ОК.
Он утверждает что не прописан в системе блок задней правой двери.
Не подскажите как это сделать? Желательно пошагово.
Postby LittleTOXA » 15 Dec 2010, 14:56
Coding: 000003
1 Fault Found
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 194
Mileage: 4644 km
Time Indication: 0
Date: 2010.11.24
Time: 19:07:35
Cannot be reached
Он наоборот в системе прописан. Можно через can gateway убрать галочку с адреса 72, убрав его из системы. Может, его и нет. Но с другой стороны - быть должен, но не опрашивается по какой-то причине :(
