VAG COM, нужна помощь
YoShee
Сообщение YoShee » 19 сен 2011, 15:18
Люди,доюрого времени суток, подскажите пожалуйста
проводил диагностику Вагом на своей машинке(А4,2002, 1.8Т, quatt)
выдал следующее
VAG-COM Version: Release 311.2-N
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01,02,03,08,09,0F,15,16,17,18,36,37,45,46,55,56,57, 65,67,69,75,76,77
Address 01 --------------------------------------------------- ----
Controller: 8E0 909 518 AF
Component: 1.8L R4/5VT G01 0003
Coding: 0016751
Shop #: WSC 08219
No fault code found.
Readiness: 0010 1001
Address 02 --------------------------------------------------- ----
Controller: 8E0 927 156 P
Component: AG5 01V 1.8l5VT USA 0910
Coding: 0001002
Shop #: WSC 63351
Address 03 --------------------------------------------------- ----
Controller: 8E0 614 517 H
Component: ABS/ESP allrad 2328
Coding: 04277
Shop #: WSC 06435
Address 08 --------------------------------------------------- ----
Controller: 8E0 820 043 L
Component: A4 Klimaautomat 1116
Coding: 00000
Shop #: WSC 63351
1 Fault Found:
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
30-10 - Open or Short to B+ - Intermittent
Address 09 --------------------------------------------------- ----
Controller: 8E0 907 279 E
Component: int. Lastmodul USA 0305
Coding: 00013
Shop #: WSC 63351
1 Fault Found:
01504 - Bulb for License-Plate Light (X)
57-00 - Electric Circuit Failure
Skipping Address 15-Airbags
Address 16 --------------------------------------------------- ----
Controller: 8E0 953 549 N
Component: Lenksбulenmodul 0308
Coding: 00041
Shop #: WSC 63351
Address 17 --------------------------------------------------- ----
Controller: 8E0 920 950 L
Component: KOMBI+WEGFAHRS. RB4 D36
Coding: 01101
Shop #: WSC 00167
WAULC68E43A239893 AUZ6Z0B0345013
3 Faults Found:
00562 - Sensor for Oil Level/Temperature (G266)
30-00 - Open or Short to B+
29-00 - Short to Ground
27-10 - Implausible Signal - Intermittent
Address 46 --------------------------------------------------- ----
Controller: 8E0 959 433 BB
Component: Komfortgerбt T7B 1311
Coding: 16236
Shop #: WSC 63351
7 Faults Found:
01581 - Incorrect Component Detected
35-00 - -
01366 - Opened Due to Crash Signal
35-00 - -
01559 - Drivers Door
61-00 - Won't De-Safe
01560 - Passenger Door
01561 - Left Rear Door
01562 - Right Rear Door
01334 - Door Control Module: Rear Right (J398)
80-10 - Single-Wire Operation - Intermittent
Address 55 --------------------------------------------------- ----
Controller: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00060
Shop #: WSC 63351
2 Faults Found:
01535 - Control Circuit for Right Headlight Range Adjusting Motor (V49)
01534 - Control Circuit for Left Headlight Range Adjusting Motor (V48)
Address 56 --------------------------------------------------- ----
Controller: 8E0 035 195 H
Component: symphony II PM6 0410
Coding: 01001
Shop #: WSC 07936
End --------------------------------------------------- ----
как избавиться от ошибок фар и подсветки номерного знака? а то на приборке мигают 2 гирлянды соответствующие..
и еще есть такая проблема в блоке 46 в адаптации
как же все таки можно в ней покопаться, а то уж очень хочется)
заранее благодарю и прошу прощение за нечеткость мыслей, я новичек)
Аватара пользователя
Re: VAG COM, нужна помощь
Сообщение SamFM » 19 сен 2011, 19:01
По фарам - менять моторчики корректоров фар / проверять проводку (замыкание не спроста пишет то). Потом адаптировать (когда подключены будут) и всё.
По лампочкам номера - менять или проводку копать. Чудес не бывает. :)
Зато, вот с автозапиранием можно разобраться. Вы не от того блока описание нашли. Кстати, есть 2 варианта (Мин. комплектация и максимальная). В минимальной нет автозапирания на 15 км/ч
Вот описания:
Адаптации
A62,5,Comfort functions
A62,6,+001 - Comfort closing via remote for window regulators (not USA)
A62,7,+002 - Comfort opening via remote for window regulators (not USA)
A62,8,+004 - Comfort closing via lock cylinder for window regulators
A62,9,+008 - Comfort opening via lock cylinder for window regulators
A62,10,+016 - Comfort closing via remote for sunroof (not USA)
A62,11,+032 - Comfort opening via remote for sunroof (not realized)
A62,12,+064 - Comfort closing via lock cylinder for sunroof
A62,13,+128 - Comfort opening via lock cylinder for sunroof (not realized)
Кодирование
C0,Comfort System (J393) Coding
C1,+00001 - GB-Alarm (not USA)
C2,+00002 - Confirmation Anti-Theft Warning System (Blink)
C3,+00004 - Selective Central Locking (SCL)
C4,+00008 - Anti-Theft Warning System
C5,+00016 - Rear Lid Release Locking at 5 km/h
C6,+00032 - Central Locking at 15 km/h (or 10 mph)
C7,+00064 - Comfort Function via Remote Control (not USA)
C8,+00128 - Right Hand Drive (RHD)
C9,+00256 - Avant
C10,+00512 - Confirmation Close via Remote (1x Blink)
C11,+01024 - Confirmation Anti-Theft Warning Sytem Horn Activation
C12,+02048 - Door-/Window Regulator Logic
C13,+04096 - Thatcham Anti-Theft Warning (not USA)
C14,+08192 - No Safe-Function
C15,+16384 - Side Windows with Insulated Glass
YoShee
Сообщение YoShee » 19 сен 2011, 22:05
Насчет лампочек - понял,спасибо большое) я просто думал,может как нить можно это оповещение отключить..а про фары - потому что стоят не родные, со светодиодами в стиле А5,там помоему ЭлДвиг нет..
по поводу минималка и максималка - точно сказать не могу... но все ништяки там есть,такие как 2зон клима, эл прив водит сидения, кожа,БОЗЕ, попогрейки,обогрев зеркал, электрорел=гулировки зеркал и все тому подобное..не знаю о чем это говорит,но думюа,что ближе к максималке)
ну и конечно по поводу адаптации - подскажите плиз, привел картинку - и так почти со всем контролерам, не могу тупо в адаптации что либо поменять.. есть идеи какие ибудь?
кстати, автозапиралку сделал только одностороннюю - в кодировке блока комфорта прибавил 48 и получился и багажник и двери, но при вытаскивании из замка - сами не разблокируются.. тоже не знаю почему((
Сообщение SamFM » 23 сен 2011, 15:50
Ага, у Вас максимальная комплектация, по-ходу. А автозапиралка односторонняя - это да. Блок не поддерживает этой функции почему-то. Придется дергать за ручку открытия двер и на кнопку отпирания жать кждый раз. :)
В остальных блоках есть адаптации, просто в некоторых нужны логины для этого. Но, в приборке и центральной электрике точно без логинов всё должно меняться.
